#122198 06/13/08 09:06 PM
Hi all - Working on a '33 commercial engine. How do I get the crank pulley back on? No problem getting it off, I used the two threaded holes in the pulley and a puller. I was expecting a threaded hole in the end of the crank but NO, not there. What now? Thanks, Ed.
A big hammer and a piece of wood. Its driven on. Don't pound on the outer rim. All Chevrolet balancer were "installed" that way. 6 and 8 Cyl., right up through the '70's.
Chevgene - Thanks, I have just the right size hammer for that job. Ed.
Make sure to install bolts in the holes to support the balancer ring. If you pound on the balancer assembly you can loosen the back piece rendering it junk.
Chip, after thinking about this, your saying to install bolts tight in the holes so that you now have an assembly which is held together by the bolts. But don't bottom out the bolts. Is that right?
32 Confederate
Bruce S. DeFord
VCCA Judging Committee Chair
Bruce,
Good point. The bolts should only go to the back of the balancer. Any longer then they dent the timing cover and can cause the crank gear to rub on the cover. Been there done that. Took a while to figure out what that noise was. Sure was embarrassing when I discovered by goof. Also messed up a balancer so know that the bolts are important too!
MRC Offline
I have a follow-up question - How do you tell if a damper is in working order?
Mine had a fair amount of gunk and rust between the pulley and the thicker heavy metal part. I soaked it a few days with penatrating oil and cleaned it up as best I could but am not sure if some critical internal parts are still rusted together or not.
MRC
MRC #122254 06/16/08 10:39 AM
As long as the pulley and metal plate will move slightly versus each other and the two parts are not too loose it should be ok.
MRC #122255 06/16/08 10:47 AM
There is no positive way to tell if the balancer is "working"...The 1933-34 Standard did not even have a balancer and I would bet that no one ever noticed the difference. In the later years, the early '60's, the balancer was eleminated from some 283 engines and it went unnoticed.
The balancer only cancels out some of the "harmonics" in the power impulses and does not balance the engine. Actaully the correct name for it was a harmonic dampner.
