bullpup Offline OP
Hi All,
Quick question...
What is the correct lube to use in a steering box for the 1941 Chevrolet?
The owner's manual indicates...
"an all season gear lubricant"
I used an 80w gear oil and it dripped out over a period of time, ruining the pitman arm bushings. I am going to pull the steering box, go through it, reseal it and replace the pitman arm bushings.
Not sure a 'fluid' lubricant is correct, maybe a thicker grease gun grease?
Thanks!!!
Paul
Paul's '41 Chevy Web Site
http://www.1941chevrolet.com
Dedicated to Classic Car Enthusiasts Worldwide
Vintage Chevrolet Club of America # 29765
You need a thicker gear oil than #80 there is a 140 weight out there but I would use grease gun grease. I also have those bushing new if you still need them. bwbugay@aol.com
The new seal should hold 140 in place....but if it were mine I would use a 50/50 mix of #80 and chassis grease. The straight chassis grease will be too "thick" to keep the bushings lubricated.
There is a product on the market call Penrite. It is a 1500 pound gear grease especially for steering boxes. It does flow and can be poured into your steering box. It will not leak out because of it's high viscosity. It can be found on EBay.
Chassis grease or gun grease cannot and will not "flow" over and around all the parts in a steering box and is a poor substitute for any type of high viscosity gear grease.
Joe ok
See Facebook Page for Joe Fuchs to see more pictures of my 1937 Chevrolet 1/2 Ton Pickup
As noted above gear grease is too viscous and won't lubricate properly. The key words when shopping are "self leveling". John Deer sells a product called "corn head grease" that is self leveling and will do a good job.
bullpup Offline OP
Thanks for the responses!
I'll add this info to the '41 website, as I'm sure other Chevrolet owners will want to know this.
Regards,
Paul
