i have a '33 half-ton truck with a 206 engine. the engine block is cracked. i have access to a 216 as a replacement. is this an easy swap? does the exisitng 206 bellhousing bolt directly to the 216 engine? are the engine mounts similiar? or, are there adapts that may be problematic? any help or direction to information is appreciated.
There is quite a bit of differences in engines. Why not find an original engine they are not that hard to find. It's not only the engine but all the other stuff you have to change. Bell housings will not interchange. Put a want add up on this site.
thank you 35 pickup man. you have saved me countless hours of research. per your suggestion, i have posted a want ad for a 206 on this site. thanks again
