To turn the engine again, make a mixture of half white spirit and half two-stroke outboard oil and pour it through the spark plug holes into the cylinder rooms approx. 2 cm above the piston tops. (Or remove the head and pour from above, if the engine is not turning after a month.) Use the crank handle to turn the engine some minutes each fortnight until it is loose and turning. Refill mixture when needed. Do not remove the engine from the frame before the engine turns again.
Start using CRC 5-56 or similar on all bolts, screws, nuts etc. some times to loosen up and avoid damages when demounting.
If you don't have a membership in VCCA, you should join. This is a great club, and you will gain a lot by being a member.
:vcca: :vcca:
