Posts: 7 |
Hello, I am restoring a 29 4dr Sedan and have been reading over the topics and it is amazing the info in here! I traded my model T in for a Chevy and have been happy ever since. Anyway, I would like to know if I should use aluminum, cast iron, or the original pistons in my engine rebuild. It is a March 1929 production engine. It was running when we took it out of the car. Your help will be appreciated!
You will get two opinions here. Some prefer iron and some aluminum. In my opioion if your going to do a lot of driving at highway speeds get aluminum. They take a lot of weight off the rod bearings. Also get the engine balanced.
Posts: 7 |
Thanks, I do plan on driving it some. Will they balance the engine once I have everything assembled? What is the procedure as I am new at this, Thanks a bunch
All reciprocating parts are balanced before the engine is assembled. A quality machine shop can do the engine balancing for you.  :) :grin:
