The 1934 to 1936 1/2 ton side mounting hardware is all the same. The tire should fit down fully into the well (there is a 1/4 inch thick pad strips in the bottom of the well). Between the tire in the well and clamp on top tightened down the tire shouldn't swing anywhere. The two straps (metal) that are riveted to the well are for an accessory tire lock. The 1.5 ton welled fender has a very shallow well because the mounting bracket keeps the tire high above the fender (you do have the deeper 1/2 ton welled fender I hope.)
