cvg99 Offline OP
Need help locating where to drill the hole for the antenna on a 55 2nd series 3100 pickup. I purchased an original type antenna but the instructions don't say where on the fender to drill the hole. Any help is appreciated.
Charlie
cvgaetani@comcast.net
Wilwood Engineering1955-1957
What you really need is the template. I have the instructions in the 1957 accessory installation manual and the template is the only thing that will give the exact location to drill the 13/16" hole.
cvg99 Offline OP
Thanks, Chev Nut, I have a template which came with the antenna I purchased, but I can't figure out where to place in on the edge of the cowl.
Charlie
Send me your email address and I send the instructions.
By the way it mounts on the fender and not the cowl.
cvg99 Offline OP
ChevGene, My email address is: cvgaetani@comcast.net.
Thank you very much.
Charlie
