#120470 05/05/08 10:20 AM
footbiz Offline OP
Did this unit have a "bug screen" on the cowl vent to prevent varmits from entering while one enjoys the fresh air?
Nope! You needed all the air you could get on a hot day. Wear sunglasses and don't open your lips too wide and you will be OK.
When you drive one of these, your lips will be so tight together, you need all the power you can get.
easymoney
