#119979 04/25/08 01:39 PM
olgzr Offline OP
Does anyone know where I can find a two row crank pulley( with balancer) for a 1958-235 motor for power steering?, or who I could call? Thanks for any help that you can give me....Richard
Wilwood Engineering1955-1957
olgzr #120026 04/26/08 02:14 PM
You can probably rent that particular tool from "Chevs of the 40's"
They ship real fast too...
The dual groove pulley balancers are very rare fOR 235 engines. I have only found two at swap meets over the past several years.
Good luck.
DD
olgzr #120184 04/29/08 02:34 PM
Contact Steve at Buffalo Enterprises, 360-652-7684. I know he modifies double pulley 292 balancers to fit the early 235, not sure if it fits the 58 235.
Are you trying to fit 60-62 235 PS pump, pulleys and brackets to your 58 235? Maybe finding the stock balancer for 60-62 235 might be easier (notice I didn't say cheaper, it's not, because they are a bit hard to come by).
