#119994 04/25/08 08:40 PM
rosey Offline OP
i have a problem with my ignition switch my car will start with switch in either position and will die on last postion (all the way to left ) what is wrong is my switch bad can it be fixed or need replaced
The ignition switches that Chevrolet used from 1948 through 1952 are rather different. When the key is turned counter clockwise the engine will be "off" and when the key is removed the switch will be in the locked position.
When truned fully to the counter clock wise position the engine will be "off", key can be removed and switch turned to the "on" position with out the key.
The "run" position is with the key straight up and down.
If your switch is not operating in this manner it would require replacing. The center lock cylinder is removed from the old switch and transfered to the new one so the same key is used.
rosey Offline OP
thank you for the help just so i understand your ansewer the three positions on the switch when the car is not on should the switch be straight up and down or to the left or right being able to remove the key is very cool but confusing in your answer both refer to the counter clock off position can you please reexplain for this newbe
Cadillac was similar to that to, wasn't it gene?
Here is the excerpt from the 1951 owner's manual: "There are two "off" positions, one to the right and one to the left of the "on" (vertical) positionand the key may be removed with the switch in any of these positions. When the ignition is turned off by turning switch clockwise, the key may be removed allowing ignition to be turned "ON" or "OFF" without the use of key. When the ignition is turned off by turning the switch counterclockwise and removing the key, the ignition is locked "OFF". Hope this helps to clarify it for you rosey.
You can also find a lot of reference material at the following website: http://www.oldcarmanual.com
Buick had this feature for years before Chevrolet, but not Cadillac.
I seem to remember that the far clockwise "off" was used for accessory, where the ignition was off but you could play the radio on a 51 is that wrong?
NO, They didn't have an accessory position.
rosey Offline OP
thanks alot all of your information really helped sorry for being such a newbe i am the resent owner of a 1950 chevy thanks for all your help
rosey,
It's a pleaure to help you but I would recommend purchasing a basic owners manual for your 1950 Chevrolet. There you can learn some of the little tidbits that will help you to enjoy all of the features of your car. The owners manual is available in reprint from www.fillingstation.com for only $9.00. They have an on-line catalog or you can call in your order....800-841-6622.
