#119938 04/24/08 08:58 PM
27Chevy Offline OP
It's been so long now since I took it apart that I don't remember how to put it back together, but I know that there are two different mounts between the axle and the rear springs. One of the mounts is taller than the other but I'm not sure which one goes on which side. Along with that question, can anyone tell me the reason for which one goes on which side? THANKS in advance for any responses!!!
Hi,
I am restoring a 28 Sport Cabriolet and actually had a spare axle for a 28. After dissasemby of the ones from the car and bead blasting them, I noticed they were different too. I then took the spare axle apart, noticing they were also different, the right one being larger(taller)also. There are casting numbers on both with the odd number being the left and the right being an even number(taller).
This is consistent with most parts where there is a left and right part. They have to go on the axle correctly or the springs will not line up with the spring hangers on the frame correctly.
As to the reason, I believe that it has to do with engine torque.
Someone indicated that could be the reason.
Chief
Chief #120046 04/26/08 08:39 PM
Hi Chief,
You have me confused. When you say AXLE that is the shaft that goes from the wheel to the differential. The axle is not position sensitive. They work on either side.
Then you make some comments that leads me to believe you are talking about the full rear end. The axle housings and the differential with drive shaft as a unit. This unit is position sensitive.
Be aware that there are two ratios for the 1928. Everything will be interchangeable except the pinion, ring gear, and side gears.
You can't install a complete rear end backwards. For example the brake rods are on the front of the rear end unit.
If this doesn't answer your questions, ask again.
devil Agrin
Hi Ray,
The original question referred to the spring hangers on the rear axle(housing). The right hanger for the right rear spring is larger(taller) than the left. I was replying to the original question as to which spring hanger, shorter one and taller one goes where. I used the questioner's term "axle" because I understood he meant axle housing.
The rest of his question was why are they different(the hangers)?. I believe it may have had something to do with the torque of the engine. The right hanger, being taller, actually raises the right side of the chassis, which would not have a passenger in the seat all of the time. Meaning, why wouldn't it be on the left side, where the driver would always be?
Thanks,
Chief
Chief #120161 04/29/08 07:29 AM
Hey Jim I have not heard about the the torque but I was told years ago it was to level the car against the camber in the road?anyway, it works well .
Jim
