#120036 04/26/08 04:38 PM
chev Offline OP
Hi 29-30-31-32 Chevrolet experts.
I look me after a new start ring gear till my 1930 Sports Roadster, for this reason a difference on the diameter on ring gear and flywheel, from 1929 till 1932? They can all use? I've got a Chevrolet friend there to have 1929 ring gear.
I know that 1929 ring gear is little slim breadth, but i mean they have all 104 teethes and have same diameter boats interior and outside on the teeth and can be use on all 1929, 30, 31, 32 models.
Sorry my British, Chev VCCA supporter 36467 Denmark
Thanks for response from you.
Best Regards
Jens Rasmussen
ornsovej 22
8240 Risskov
Denmark
chevrolet@rasmussen.mail.dk
chev #120038 04/26/08 05:52 PM
The ring gear on the 1929 has 42 teeth and 11 teeth on the pinion gear(3.82:1 ratio), Chevrolet set p/n 361922. The 1930 & 1931 ring gear has 41 teeth and the pinion has 10 teeth (4.10:1 ratio), Chevrolet set p/n 362737. 1932 up had a 4.11;1 ratio (37-9 teeth).
35 pickup man, I think that he is talking about a fly wheel ring gear with 104 teeth.
Sal Orlando
Chat Group Region Member
1931Sal #120047 04/26/08 08:57 PM
Now that I look at it again I think your right, thanks for the correction. I have been rebuilding my truck differential and have my head up my rear end.
i had to acquire an new ring gear for the flywheel on our unrestored 29 convert landau. after receiving several ring gears purported to be correct(and finding they were either too small or too large to press on the original, unmolested flywheel) i did a google search for flywheel ring gears and came up with an outfit in australia who supplied a ring gear that fit. suggest you accuratly measure the OD of your flywheel and proceed with the search for a replacement. god luck, mike
Hi Guys,
Here is the guy that you need to talk with, I just bought one from him at the Portland Swap meet. He reproduces flywheel ring gears.
Al Suehring: Flywheel Ring Gears
10058 Krogwold Road
Amherst Jct. WI 54407
715-677-3809
al@suehring.com
Bruce
32 Confederate
Bruce S. DeFord
VCCA Judging Committee Chair
chev #120072 04/27/08 09:21 AM
These replacement flywheel ring gears did come with a couple different inside diameters and widths. I have a couple of them, but as previously suggested ,measure your flywheels diameter. first. bwbugay@aol.com
chev Offline OP
Thanks for your help all.
Best Regards
Jens Rasmussen
ornsovej 22
8240 Risskov
Denmark
on my early cars they do not have replaceable starter ring gears and they are not listed in the parts book . i guess mine must have been molested ?
I just sent you a PM, Jens.
:vcca:
Solan G, # 32797
chev #377187 10/19/16 08:03 PM
Hello new to vcca can anyone help me find a pinion gear for my 29 chey it has 11 gears on it
The ring gear and pinion gears are matched sets and were sold as a set. It would be advisable to replace both.
chev #377194 10/19/16 09:11 PM
Looking for advise from anyone where I can find a ring & pinion set for my 29 chevy any help is greatly appreciated
Tim, I'm here in NC and I have both a ring and pinion set and a complete 1929 rear end. I'll send you a PM with my phone number and email.
All the Best, Chip
"It's wise to choose a SIX"
