#119554 04/17/08 04:34 PM
Oldie Offline OP
Before you place that old non-ferreous metal item at the curb for the trash man to pick up, think about this:
Today I was doing some spring clean up and needing to dispose of some useless sheet metal items that had been used as donor parts for a recent restoration, I decided to take the stuff to the local re-cycle place. Not worth much and my garbage pickup won't handle it, so what do you do? 180 pounds of old sheet metal, springs etc. netted $4.50 and they're gone. I also took two old radiator assemblies, a '26 with a modern core and bent up tanks, a '27 with honeycomb core, split from top to bottom, with usable tanks, maybe. I had carted both radiators to many Swap Meets over the years with a $20 price tag on each with no takers. I was tired of walking around them. The Re-cycler paid me $47.15 for the pair, 41# total @ $1.15/lb.
A couple of months back I took four aluminum alloy wheels to the same re-cycler. Those wheels had corrosion at the bead seat areas and had difficulty holding air pressure, so I wasn't comfortable selling them to anyone. That netted me $49 and change for the four wheels.
The moral here is, years back you couldn't give this stuff away and much of it ended up in a land fill. Today, someone is willing to pay you for it.
Oldie #119556 04/17/08 05:49 PM
Scrap metals are at an all time high right now.....sorry to say that its China thats paying the high prive for scrap metal.
Tonight while cutting the grass I noticed no less than 3 trash pickers cruising the neighborhood. The trucks were full of gas grills, wheel barrows, childrens slides, swing set parts and almost any other type of metal object. If you have the room to save a trunk load or pick up load of scrap metal it is only going to pay more money over the coming months. The trick is to plan the trip to sell it so it does not cost more in gas to sell it !!! $3.45 gallon for cheap gas today!!!!
Member 45+ years, been around since the beginning !
