Okay, we've gotten our '33 Eagle out of mothballs with some triumphs and a few tragedies, but it's just not running right.
It seems to be missing, it backfires all-too frequently.
We've replaced the coil, plugs and wires. It puts out one HECK of a spark … I'll bet it'll just 3/4 an inch. We my father pulled the #1 wire off, it "bit" him and he dropped it. It was then jumping through the boot and paint on the fender, presumably to the metal beneath.
We've adjusted the tappets to .008 and .010. It doesn't rattle.
All six cylinders have virtually identical compression … 75 psi. That's decent, isn't it? But at least they're all consistent, which would seem almost more important.
If you pull off ... ahh, crud, I can't remember the firing order, so I'm going to say #1 is closest to the fan and they just go back to #6 at the firewall. I know that's not the order, but if you follow that, you'll know what I mean.
If you pull off the plug wire on #1 or #2, it'll keep running at an idle with little difference in note. Pull off either #3 or #4, and it dies; #5 and #6, and it doesn't sound but slightly worse than pulling off #1 or #2
Yet, it'll still pull itself up onto a flatbed trailer. It'll pull at a lot lower RPM than I'm comfortable with. (Too much time in my Toyota, I'm sure.)
Thoughts? Anyone willing to volunteer to have me call them and hold the phone next to the motor and tailpipe?
The filming experience, from a car point of view, has been good ("'33 HELP!" subject). Our wranglers have some idea of what they're asking of the Picture Cars and their drivers. So do their wranglers. I'm pretty sure, however, that the director himself either does not, or doesn't care. There is a lot of standing around and waiting for SOMETHING, but not knowing what. Then when it's time to go somewhere, it's absolutely right now, with people literally running to get things started and moving.
However, there has been one tragedy. We were hauling the car on an open trailer … had done so before with no problem … on Saturday, and we looked back, and there was something poking up off the top of the coupe.
We stopped to investigate.
Our soft-top insert is just plain GONE. Everything from the wire screen up. Tore up the headliner a little bit too.
Of course that was all original, so that's fairly upsetting.
Does anyone have a recommendation for a place to get an estimate for replacing the top and headliner?
Grianainech (Michael)
