Posts: 100 |
Can any one tell me the correct battery cable length for both positive and negative cables on a 29 4 door sedan. thanks for your help.
Do a search on Chevy Chatter II. I believe that the lengths were listed on this site several weeks ago.  :) :grin:
Posts: 100 |
Ha Junkyard Dog. Tried every possible question and can't find the answer I am looking for.
Posts: 100 |
Still can't find battery cable lengths for 29 four door. Could some one please tell me the length of both the positive and negative cable's in lnches thanks.
You can make the mesurments and find the correct length of the cables. The + cable runs from the + post on the battery to the starter switch. The negative cable (strap) would run from the - post on the battery to the top of the transmission, to the frame, or to the starter bolt on the bell housing. Use very large cables. The bigger, the better.
For 1929, the positive cable is 27" long, and the negative cable is 7" long.  :) :grin:
