#11844 02/23/05 10:44 PM
Do they have the Freewheeling tag in reproduction? If not does anyone have an extra one they will sell? :eek: laugh Thanks
Jerry Million
#11845 02/24/05 12:16 AM
Check with the Filling Station in Lebanon, Oregon. I think that they might have them. laugh laugh laugh laugh
#11846 02/24/05 07:53 PM
Thanks JYD but they looked and there not in catalogue or warehouse. As a matter of fact he asked me to contact him if I found a source. Can your sources in the USA either get one to him or find someone to repo this item. It would seem to me to be a worth will effort.
Again thanks to who ever set this up, sure help in the restoration process and also provides a good daily read for other items and years.
Jerry Million
#11847 02/24/05 08:38 PM
I have a 10 year old repro that I will part with. E-mail me bwbugay@aol.com
#11848 02/25/05 12:35 AM
Former ChatMaster
ChatMaster - 5,000
Former ChatMaster
ChatMaster - 5,000
You're welcome.... wink
Bill Barker
(VCCA Member: 9802)
#11849 02/25/05 12:36 AM
xxx Offline
Can you post a picture of the reproduction tag on Chatter, chevy b?
Thanks, croc
#11850 02/25/05 12:01 PM
Gator,
What is a freewheeling tag?
Uninformed, John
JOHN GILL
#11851 02/25/05 01:15 PM
The 1932/33 cars had a freewheeling feature attached to the rear of the transmission. This feature 'disconnected' the transmission from the 'drive' condition when you removed your foot from the throttle. Above the steering column on the dash was a large knob that allowed the driver to either use the 'feature' or leave the transmission in gear under all conditions. The 'feature' did not find favor with drivers when they were going downhill and the engine did not provide any braking power. Provided the 'feature' was engaged.
On the engagement knob was instructions on the operation of the knob. I assume this is the tag they were talking about.
A tag was also on the dash of the 1927 cars, however it was labeled 'coasting'.
Agrin
#11852 02/25/05 03:20 PM
Thanks Ray,
One learns something new every day! Kind of a "poor man's overdrive". :)
#11853 02/25/05 05:40 PM
I have a 3 speed transmission with the freewheeling unit attached, no cable or tag. Unit does not have the shift lever either. If any body needs one contact me.
#11854 02/25/05 07:09 PM
xxx Offline
Thanks for the answer Ray.
I really like using the free wheeling feature, but I don't have any hills to worry about either.
Wouldn't this save gas? Also you aren't using your tranmission as a brake.
Was this feature only offered in '32 or not? :confused:
If someone can post a copy I think with computer programs we could make reproductions of it without any problem. :eek:
croc
#11855 02/25/05 09:40 PM
Originally posted by AntiqueMechanic: "The 1932/33 cars had a freewheeling feature attached to the rear of the transmission."
As Raymondo mentioned, both 1932 and 1933 had freewheeling. laugh laugh laugh laugh
#11856 02/25/05 10:34 PM
xxx Offline
I assume than the answer is only '32 and '33 had freewheeling or is it changed when Ray said "A tag was also on the dash of the 1927 cars, however it was labeled 'coasting'."???
Coasting and freewheeling is the same isn't it? I am asking about freewheeling feature on the cars not the trademark term Freewheeling, if it was trademarked by Chevy.
So which years had the freewheeling/coasting feature?
As a point of intrest was this feature ever offered on trucks?
croc
#11857 02/26/05 12:22 AM
Hum.........okay, Freewheeling was used in 1932 and in 1933. 1932 was the first year and 1933 was the last year. It was not offered on the 1932 or 1933 trucks. laugh laugh laugh laugh
#11858 02/26/05 12:24 AM
The old mutt did some detailed investigating, and it seems that the Filling Station might have a "stash" of Freewheeling tags but they don't know where they are. :eek: :( :( mad mad mad
#11859 02/26/05 02:52 AM
Gator,
I don't think freewheeling would save much on gas if you have a steady throttle foot and it prevents the engine compression, through the transmission, from helping to slow the car, so it was dropped after two years. It wasn't used on trucks, they need all the help they can get for braking and maybe the freewheeling unit is not as strong as the rest of the transmission. I never enable freewheeling on my car.
George
#11860 02/26/05 08:35 AM
I think Freewheeling is just what the term implies. It's just like stepping on the clutch or putting the trans in neutral.
I don't know what GM had in mind, but while on a down grade this feature can be very dangerous. I think that's why it was only offered two years.
I have never used mine. Only once to see if it works, but never again.
I guess in the old days someone may have used it on a five mile down hill, but most cars where new to to masses and the feature was a marketing gimmick.
Overdrive gears made more sense and eventually would win out.
As for the hanging paper tag, I have seen them for sale from the Filling Station and I'm sure they will be offered again. I personaly don't want one, I think it looks silly. Kind of like paper floor mats and plastic covers on the seats. To me, "as delivered" has it's limits.
Chat Group Chapter Member
Current rides;
1968 Camaro rs/SS 350 4spd
2000 Blazer LT
2005 Malibu Maxx
2007 Acura TDX
Last total restoration;
1932 Sport Coupe
#11861 02/26/05 10:17 AM
This car will be displayed at a GM show room in 2007 for the 75th year. I hope to have all the show room details. As to the daily driver thing, RGwiz you are right the tag has no added value. This car has never been to any show, convension, display and is in it's finally stages of a 30+ year restoration process that began 3 people back. It is driven daily in the summer even will under restoration. It may be the last 3 window Canadian built car. Only 525 were ever built in Canada. As to the freewheeling like RGWiz said I tried it once, very dangerous thing, have locked mine out. Still hoping to find a "Freewheeling Tag" USA or Canadian printed. Reproduction or original. Thank again for the Forum.
Jerry Million
#11862 02/26/05 01:55 PM
I have the freewheeling tag hanging on the freewheeling control knob and It looks great. It adds alot to the dash to have It there. If anyone has freewheeling, Then they should have the tag.At car shows and whereever people have looked at my car, I get many many comments about the tag and what It says about useing the freewheeling. The tag Is there for a reason and not having It Is a big big mistake. chevy
#11863 02/26/05 07:45 PM
As I understand it, freewheeling should not be compared to overdrive, except that both are transmission related components. Different as apples and oranges.
#11864 02/26/05 07:57 PM
You are absolutely correct. Freewheeling was a two year (1932/33) characteristic that allowed the car speed to go faster than the engine speed. However, the engine speed would not go faster than the car because it would be engaged full time. The engine would propel the car faster with the increase in engine speed.
By definition an overdrive would increase the speed more that the direct drive, or OVER the DRIVE speed.
Agrin
#11865 03/03/05 12:13 PM
safety inspectors in the 40'sthru 60's in the western states where i worked were required by state law to verify that any disconnecting device had had its cable cut and that the engaging mechanism was wired OFF. that law may still be on the books out here at least. When my dad bought the 32 in about 1946 it was already done on it.
they just don't make 'em like they useta
#11866 03/03/05 01:19 PM
Engine braking was very effective on the older cars due to the 4.11 rear end.It assists the braking power when stopping....that being said I have ridden with people that depress the clutch (when preparing to stop) at 30 or 40 miles per hour which causes the car to free wheel in the same manor.The owners manuals, etc. suggest not depressing the clutch intil 10 MPH to help take the full load off the brakes.This is the way in which I was taught to drive.
#11867 03/04/05 02:08 AM
xxx Offline
Didn't Free wheeling also change how you could shift the car with it engaged you didn't have to use the clutch? :confused:
croc
#11868 03/04/05 10:47 AM
Check out the owner's manual. It gives a full explanation of how to use the Freewheeling feature. :cool2: laugh laugh laugh
