Posts: 27 |
In an earlier post I asked about taking apart a horn relay to check to see if it is working. Well, it is....But the horn will still not sound. I removed the "half sphere" cover on one of the horns and found a little bit of whittish powder (probably a little corrosion) and a lot of wiring and windings. Can I use electrical terminal cleaner (in a spray can) to clean up this area? Or is there something else better that can be used.
Bob
Yes, you can use the cleaner for the entire area and then use a point file to clean the points. You can also use a finger nail file. Do not use sandpaper as a grain of sand could become lodged in the points and it would not work.
Posts: 27 |
Thanks Ray, I'll give that a try Bob
