#117448 03/13/08 05:58 PM
Can someone tell me how one goes about removing & install a ring gear on the flywheel of a '31 - '33 chevy?
thanks
Not a job for an owner/operator.
Use a cold chisel to break the gear that is on the flywheel and remove.
Now we need some very accurate measurement. The diameter of the flywheel at the bottom of the wheel where the other gear was mounted. The correct diameter measured on the INSIDE of the new ringgear. Assuming the new ringgear is slightly smaller we are ready to install the gear. Mark the spot on the flywheel that was TDC. Insure the new ring has the same mark. Remember these two spots when assembling.
Place the flywheel in a freezer. Place the new gear in a pizza oven. When both items have achieved the hottest and coldest, place the ring on the flywheel. A large brass hammer, leather welding gloves, and a set of tongs will ensure a complete job.
If you can find a suckXX, the extra help will prove to be very helpful in the new assembly.
Agrin devil
Floridaboy: I sent you a private message yesteday in answer to your private message regarding the flywheel ring gear. As of today it is still unread. You might want to check it out.
wink :) :grin:
Floridaboy: Also, in case you are not aware, your email address that is posted in your profile doesn't work either. I sent you an email and it came back as "mailbox unknown"!
:o :( mad
Sorry.........I've needed to update my e-mail ......finally got to do it after seeing your posting. Could you try again?
floridaboy--follow Ray`s advise and you will get the job done. I`ve replaced several ring gears on Chevies and F--ds doing it exactly like Ray explained with 100% success.
hoppy
"Four-Doors-Forever"
Floridaboy: You still haven't read your private message!
wink :) :grin:
