#11686 02/14/05 07:22 PM
Are the three round head screws that hold the chrome cover on the horn chrome or painted black? Thanks
Dick
#11687 02/14/05 07:55 PM
They are plated and depending what Chevrolet literature you look at depends on the location of the screws. Some pictures show two screws across the top with one in the center on the bottom. Other pictures show one at top center and two on bottom. Take your pick.
See you down the back roads.
Joined VCCA June 1, 1961
#11688 02/14/05 09:44 PM
Was there only 1 horn on the 31 coach and was it on the drivers side? Thats where mine was when I got it but it doesnt work, so someone but a aaoooga horn under the floor. I would to put it back origional like the rest of the car. Is there someone who repairs them or can you buy new?? thanks
#11689 02/14/05 09:51 PM
All 1931 passenger cars came with one horn on the driver's side as standard equipment. laugh laugh laugh
#11690 02/14/05 10:09 PM
JYD: i sent my 31 horn to c t nuxoll as you suggested. real nice fella on the phone. he just sent it back and said he couldn't repair it due to a short in the coil. you or anybody else know of the whereabouts of a coil for the old horn? perhaps a coil out of a later 6 volt chev or GM horn might serve as a donor. any ideas? thanks, mike
#11691 02/14/05 10:38 PM
Mike,
The coil should be able to be rewound. I have never tried it but maybe an generator armature rewinder could do it or at least supply the wire so you could do it in front of the TV on a cold winter evening. All it should take is the lacquered wire and patience.
#11692 02/14/05 11:14 PM
Mike,
I bought my origional horn at a swap meet for three dollars. I recoginized it from pictures I had seen. It did not work. I hooked a battery charger up to it and turned that little screw. When it started blowing everyone in the shop jumped. It works great!
JOHN GILL
#11693 02/15/05 12:32 AM
Some people are lucky and then there are the rest of us.
#11694 02/15/05 12:44 AM
Yes, Cecil Nuxoll is a very nice dude and he does high quality work as well. You can rewind the coil yourself and the correct gauge wire is also available to do the job. yipp laugh laugh laugh
#11695 02/16/05 10:09 PM
This is another source of horn rebuilding:
The Horn Shop
7129 Rome-Oriskancy Rd.
Rome, NY 13440
Call (315) 336-8841
Doug
#11696 02/17/05 09:27 AM
thanks doug. mike
