my chevy has always had a stumble while crusing. it does not seem to happen under acceleration and I just noticed it (seems) to happen worse when I use the headlights, it is more pronounced when I advance the timing a bit using the octane selector. I have changed carburation in the past because it felt like a carb problem with no improvement. any ideas?
J Franklin
Is it a serge? A serge is a slight bucking when running at a steady speed usually between 40-60 MPH. My 1939 will do this if the timing is advanced too far and was typical for 1939's. For the 1939 it was a case of a lean fuel mixture + too much advance. Your metering rod may be improperly adjusted or incorrect metering rod and main jet for a 1936. Do you know what year carburetor you are running? Also if the heat riser is stuck and the intake manifold is getting too hot this can happen. Possible weak condenser or coil, especially if its worse after driving some distance and every thing is heated up.
I have replaced the coil, good vacuum advance, 4000 miles on a rebushed rebuilt dist. Maybe i'll next change the condencer. The carb was changed it now is a modern holley of a 200ci ford 6 with an electric fuel pump and a regulator at about 2 1/2 lbs. The symptoms haven't changed.
J Franklin
I would have replaced the condenser first...cheapest and easy to do....There are no bushings in a 1929-62 distributor. :confused:
