#116103 02/19/08 10:05 PM
I have a wooden floor board in my 37 that I know is not original but it fits like it was made for it,the parking brake and 3 speed shifter come out the holes perfectly so what year is it for. Its in two pieces,one large piece and another thin piece where it meets the toe board. I do not need it any more since I have found a correct metal floor board so I need to know what year its for so I can find someone who needes it. Jeff
VCCA #45194
Jeff -
It's possible it was made by someone to fit your truck. On the other hand, the 36 second series pickup had a wooden floor board. I'll let someone else chime in and tell both of us if the 36 second series, 37 and 38 floor board were the same. While the 36 second series cab resembled the 37-38 cab and looks almost exactly like a 37-38 cab, there are some minor differences that may not be evident when it comes to something like the floor board.
Joe crazy
See Facebook Page for Joe Fuchs to see more pictures of my 1937 Chevrolet 1/2 Ton Pickup
All the high cab 1934-1936 trucks had wooden (plywood) two piece floor boards and the single units trucks (panels, Suburban and canopy) have the same boards throughout the year. The low cab should be an all metal floor board all though I prints that show what looks to be a wooden floor? . 36 low cab floor p/n 477277 pickup and p/n 477301 1.5 ton low cab were different than the 37-38 p/n 594993 (4 speed) and p/n 594987 (3 speed). I'll try to do a thorough search in my truck data.
Of the 1/2 dozen of 1936 GMC low cabs that I know of, mine included, all have plywood flooring. This may have been a GMC thing,since all GMC's made that year were at the Pontiac Plant. I would be interested if anyone has seen a 1936 GMC with a metal floor and if the Chevrolet floor would bolt right. I would think that it would, since they were identical cabs.
1936 GMC T-14 low cab. TA for 1935-37 GMC, Director of the Gulf Coast Region
Well that verifies my Chevrolet Indianapolis prints now that I have dug them out; they do show a wood plywood floor in the low cab. Thanks for the update. All my trucks are the 34-35 and I have one High cab 36 parts truck. GMC at least in the high cabs were the same as Chevrolet. The GMC ID tag & location was different and there are some other small parts in the GMC. It isn't unusual for GM to make running changes during the production year.
Dunfire just sent you an e-mail with attached picture of the body print showing the floor board.
When my uncle retired my 37 he took the original floorboard to remove the battery and lost it,this wooden one came from what I thought was a 37 but since it was just a cab on a chassis it could of been a 36. I needed a floor and since the wooden one was available I grabbed it,its getting the correct metal floorboard now. Jeff
VCCA #45194
Jeff -
I have been looking for a metal floor. May I ask where you came up with it?
Joe crazy
I got it off someone through the internet,I thought I would never find one but there is a company called direct sheetmetal that makes a floor with a stock firewall which was going to be my next stop. Jeff
VCCA #45194
My 36 has a wood floor and wood cab to frame blocks.Its a low cab and the front window is 12 in. high in the middle.And has a flat dash like 34&35 witch i prefer.And it needs the window bars that go on the sides of the front window frame that holds it open? but its a old truck so in the last 72 plus years how knows?Whats what.
You have a military or Government truck (C.C.C., Forest Service, W.P.A etc.) ordered directly from Chevrolet and their Bid specified either a normal crank out windshield or the swing arm type which they used the same as 34-35 dash and swing arms. The swing arms are longer than the normal 34-35 so the windshield would open almost 90 degrees.
Pickup Man,
Any chance you could send me a copy of the floorboard prints. I'm getting ready to re-do my 36 FB low cab's plywood floor. Thanks!
WW
1936 Low Cab Pickup
Would you be interested in my wood floors as I wont be using them and they are in nice shape for their age,they are for a 3 speed and were in my 37 but I have since found the correct steel floor for it. Jeff
VCCA #45194
I can make a set of drawings for you of the 34-35 and 36 high cab floor plywood boards; do you have a 3 speed or 4 speed transmission? E-mail me your postal address too.
