Posts: 89 |
can anybody tell me where i can get a "Fisher Body Service Manual" 1926-1931 someone told me this will be helpful in installing my head board and windshield regulator thank you
Filling Station or other reprint dealer. Crank n' Hope in PA reprinted them.
Posts: 89 |
Posts: 184 |
 On the subject of the windshield regulator, does anyone have any suggestion on how I can go about getting a slight warp out of the windshield regulator board? One of the regulator assembly axes points rubs the edge of the inset hole. Sighting down the board you can see a slight bow. :confused: Finally found regulator assembly for 1930,  I am ready to let the one for a 31' go. E-mail if there is interest.
Seeing the USA in a (1930) Chevrolet
Posts: 184 |
Is there an e-mail address for Auto Wood Restoration?
Posts: 89 |
This is where I just ordered my board he is a very nice man I cant wait to get it and see how hard it is to put back together
Posts: 184 |
:confused: :confused: How is the regulator board attached to the upper portion of the metal frame. I know there are four mounting hole in the regulator board and there are four threaded holes in the frame. Once the regulator is mounted to the regulator board the upholstery is applied. My question is; are the mounting bolts pushed through the fabric, or is the fabric pulled back, bolts placed and then the fabric tacked over? Does any one have pictures of what it looks like? A picture is worth a thousand words.
Posts: 89 |
no i dont have a picture i wish i did i am waiting for the board from mr rodman and then it will get fun i have ordered the fisher body manual from filling station somebody said it will help after i get all the stuff maybe i can give more info or i will take any info that is out there
Posts: 184 |
After doing some investigative work I came up with the same conclusion. JYD you summed it up nicely. The "Fisher Body Service Manual" gave a hint but the "A Pictorial History of Chevrolet 29-39" provided me with the best view of the header area. Question, is there any other book out there that provides a more detailed photographic view of the Chevrolet interiors, and close ups of body, and mechanical features? Is there a source for the nickel plated oval head screws and cup washers?
The regulator is attached to the board then the upholstery and thin cotton pad covers the board, is nailed to the back side and then screwed in place. The screws in the top of the board adjust the board up and down.
Posts: 184 |
 I do not have the original mounting screws. The header board was on the back seat.
Posts: 184 |
Posts: 89 |
boy this sounds confusing the fillin station told me the fisher body manual for 29 to 31 is back ordered and they dont have the screws that adjust the board any one have any idea where i can get them i too am trying to put my 31 header board and regulator back together
Go to you local hardware store and get the slotted oval head machine screws and finish washters. I have not checked but think they are 1/4"-20 and nickel plated. Stainless is a good alternative. If the store does not have them then go to a an older store. Slotted screws are not generally made today so old stock is your best bet. Or you can check on line at one of the numerous fastener sites and order them. Several were posted a couple of months back. If you do a search it should turn up the websites.
Posts: 11,162 |
FYI...I have found several screws that I needed at Lowes in the special fasteners bins....Also I have found the SS slotted oval head screws and the finish washers at a commercial electronics store, ask for panal mounting screws and washers, only thing is they may be 10-32 screws, I have found some of those on my 28. also some 8-32s when I need a new screw I just retap the hole to 10-32 since I previously did a lot of electronic panel mounting.
Posts: 89 |
how about the moe hair? the rest of my car is already done is there a place where i can buy just the piece to cover the header board?
Posts: 2,073 |
Tools; Your best chance of getting a small piece of mohair is at the upcomming flea market held on 2/6/05. It's at the American Legion Post 455, 2 Meadowbrook Lane, New Egypt, NJ. Hosted by The Historic Region of the VCCA. For more info call Dennis Siciliano at (609)894-9421.
Chat Group Chapter Member Current rides; 1968 Camaro rs/SS 350 4spd 2000 Blazer LT 2005 Malibu Maxx 2007 Acura TDX Last total restoration; 1932 Sport Coupe
Posts: 316 |
If the Filling Station is out of the manuals you can also try FAXON Auto Literature 1-800-458-2734 They will have what you need. As for the header board screws you can try a marine hardware store. They should have what you need, in nickle chrome slotted with trim washers. If you need all 4 it is a good idea to buy several spares while they are still avilable. They should be 1/4-20 .
See the USA in a Vintage Chevrolet
