Posts: 19 |
My '37 pickup engine number stamping is K210625.I have only seen this in one list to verify this number as 1937.Can anyone tell me more about my truck by decoding the engine number.I've tried searches without much gain. Thanks in advance!
It's not the speed you travel it's the quality of the trip that matters !!!
All 1937 1/2 ton truck engines began with K. This identified it as a 1/2 ton truck engine. The flllowing numbers were just production sequence numbers for a 1937 engines. They ran from 1 up to 1187821. That is the only info. that can be determined from the engine number. Can you find the serial number? Should be on a plate on the firewall.
Note that the 1937 engine number is stamped into a little raised pad next to the fuel pump. From 1938 and up it is on a ledge behind the distributor just below the push rod cover.
Posts: 19 |
Thanks CHEV NUT the fire wall plate says Master then Car No 3GC11 followed by 2647.Let me know if that has any info contained in it.Do you recommend a source for vin research ? Thanks again
Posts: 988 |
You have a St. Louis built (3) 1/2 ton (GC) built in Nov. 1936 (11) and is the 1647 truck (build starts with 1001.
The 3 indiactes that it was assembled in St.Louis....so its a "transplant"....California vehicles were made in Oakland. The G = 1937 The C = 1/2 ton The 11 = it was assembled in Nov. of 1936, 2647 is the production sequence number for a 1/2 ton. Low number would indiacte and early vehicle as indiacted by the 11-36 assembly date.Production began in Nov.
Can't help on the number search.
Posts: 19 |
Your right it's transplanted by me.Now I know when and where my trucks story started.Thank you both for taking the time to help !
