#110824 11/19/07 12:34 AM
Was curious as to whether all convertibles from 46-48 had power tops or electric tops. Some of the shop manuals I have looked at show the power top. I am looking at one possibly to buy and it has a manual top. Thanks
Ken
reborn55 #110833 11/19/07 03:56 AM
As you face the firewall, on the drivers side, do you see a large cylinder, mounted vertically? If not, are extra holes seen on that section of the firewall?
Agrin devil
reborn55 #110858 11/19/07 12:06 PM
The 1940-41 convertibles had vacuum operated tops.
The 1942 was eletrically operated.
The 1946 and up were hydraulic.
Chev Nut #110866 11/19/07 12:56 PM
The factory shop manuals for '42 with the orange cover are the same - word for word - as the shop manuals up to '48. The '48 manual has a dark blue cover and still has the '42 info on the power top. The Service News bulletins are necessary to update to '46 - '48. Reprints are available from Bob Hensel at Chevy Acres, 116 Oak St. Brillion, WI 54110
reborn55 #110868 11/19/07 01:32 PM
Hello: So, to answer your question, yes, all 46-48 Fleetmaster Cabriolet models DID come with power tops. If the car that your looking at is complete, except that its missing the pump and or cylinders, there are replacements available. I would want to take a good look at the top hardware to confirm that it had not been otherwise changed or modified when it was made manual. I need to send my original pump out for rebuild myself and I have found a pretty good group that seems to know what they are talking about. Check out Hydro E Lectric at http://www.hydroe.com/ I found them in Hemmings.
PDXjoe #110896 11/19/07 07:17 PM
Joe, Whats wierd is the 1942-46 shop manual that I have mentions that the top is operated by two reversible eletric motors....and the 1946 had a hydraulic system and the manual makes no mention of it. The copy write on the manual is 1942 so they must have justchanged the cover to blue and added the 1946 to the title. I can find nothing else refering to 1946 in it.
Chev Nut #110904 11/19/07 10:24 PM
Thanks for the info. The car I am looking at is a street rod. supposed to be an original convertible. It is in Idaho and I am in Illinois. Has a manual top and thought members here would be best qualified to answer questions. It seems that a few that have been rodded have the manual tops. Thanks again.
Ken
reborn55 #110923 11/20/07 08:46 AM
When they removed the hydraulic power top hardware, the pump on the front of dash, the cylinders from the qtr inner area, the lines on the floor along the tunnel, and electrical feed for the pump and relay, they may have also elected to change to a Carson or other style top. Really it's only relevant if you want to go back to the original setup. Maybe you will be completely satisfied the way that it is. The 46-48s were all hydraulic systems. The confusion around the language in the manual is something that I have struggled with too, but the systems for these years were hydraulic. In my experience, the manuals almost add more confusion than they help. They are not very clear in their descriptions, but still worth reading.
Thank you for all the info. Top works very easily and fits well. It is also new so I will probably stick with it if I purchase the car. wife likes it so it may be a no brainer. Thanks again.
Ken
