Posts: 2,262 Likes: 6
Posts: 2,262 Likes: 6 |
When I removed the fuel line between fuel pump and carburetor on my '30, there was a clip on it with a hole for a 5/16" bolt, but it wasn't attached to anything. I assume this attaches somewhere at the front of the engine to support the gas line where it passes under the water pump. But exactly where should it attach -- on one of the bolts for the timing gear cover? (If so, which one?) Or somewhere else?
Thanks for any help.
All the Best,
Chip.
"It's wise to choose a SIX"
Not aware of any fuel line clip attached to that gas line.  :) :grin:
There is no clip on the '30 fuel pump to carb line. There is a support on the '32 and later pump to carb fuel line with downdraft carb as the line is longer and with more bends also more flexible.
Posts: 189 |
Hey Chip, is there a chance you could be working on the oil pressure line instead of the fuel line? The oil line from the engine to the gauge has a small bracket.I think the oil line is 1/4" and the fuel line is 3/8".Hope this helps,Stan
I think Chipper has hit on the right answer. This car had a Carter W-1 downdraft carb and manifold on it when I bought it... and I assume the gas line came with the carb when the old updraft was changed out. Since I'm of course going back to the old RJH-08, I guess we can call the clip "excess to requirements".
Now I have an extremely valuable fuel supply line anti-vibration mounting device (very rare) for my collection. I may be willing to part with it for big $$$$$, but I think I'll keep it.
Thanks for solving the mystery Mr. Sweet!
All the Best, Chip.
