Posts: 410 |
I ran a search on this , but did not find any info.. My thread pitch gauge shows 12 threads per inch on the head bolts is this correct? Cleon
Posts: 29 |
You can buy the proper bolts and tap from The Filling Station in Lebanon OR.
Don C #14476 VCCA
DonC
Posts: 242 Likes: 1
Posts: 242 Likes: 1 |
Yes Cleon thats right (british) .
Jim
Posts: 1,213 Likes: 1
Posts: 1,213 Likes: 1 |
According to my 1940 4 Cyl Master parts book,the head bolts are 1/2" X 12 U.S.S.Whilst they may appear to be 1/2" Whitworth thread(English thread,55 degree thread form angle),they are a special American thread form.They still have the 12 threads per inch the same as the English Whitworth,but the thread form angle is 60 degrees.
CJP'S 29
Posts: 410 |
Thank You for the information 625jim and cjp'29. Cleon
I have tested the new head bolts that are sold by the Filling Station. They are exact as the original bolts. Although they are the same length as the originals they should have been made 1/4 inch longer. When using these new headbolts (or any headbolt) make sure the holes in the block are cleaned thoroughly. Dig out any debris and blow out with an air hose. You can use more torque on these new headbolts. I suggest 65 pounds. Although you could use more, it could result in a damaged block.
