Hi 27Chevy,
Here are some dimensions for the brake lining for your '27.
External service brake lining: 34" long X 2" wide X 5/32"
thick.Though you may be able to use 3/16" thick lining,and
if you can,you'll get a bit longer service use out of the
brakes.
Emergency brake lining: 28" long X 1 1/4" wide X 5/32"
thick.Again,you might be able to use 3/16" thick lining,but
that will depend on the drum bore to lining clearance,with
the hand brake released.If the clearance is too tight,you may
have to revert to the 5/32" thick lining.
The correct oil for the differential,gearbox & universal joint
was 600W SUPER CYLINDER OIL.It was used on some steam
locomotive parts as well as stationary engine too.This oil is
a straight mineral gear oil,with NO fancy additives.The modern
equivalent grade works out to be a straight mineral gear oil
with an SAE rating of 140.
If you can find a MOBIL oil distributor anywhere near you,
they should be able to help locate the 600W SUPER CYLINDER OIL
for you.
Hope this information helps you out.
