Tony53 Offline OP
This may sound like a dumb question, but I had my grill re-chromed about 4 years ago, and the plater didn't do a very good job on the centre bar (this is the horizontal piece that the teeth attach to). There is some pitting starting along the top of it. Can this section of the grill be removed without taking the entire grill off the car as the rest of the grill is acceptable, so I prefer not to dismantle it.
Also is there anything I can put on the pitted section to stop it getting worse such as lubricant spray ?
Thanks, Tony
Tony- 1953 sport coupe
Sydney, Australia
The grille parts were originally riveted together at the factory. When a part or parts are replace or the grille rechromed it is bolted back together. This shold allow you to remove just the center section although it may be difficult.
To stop the rusting a wax that does not leave a white powder when dry can be used - or the rust removed and the area coated with a clear lacquer or epoxy spary paint. If the car isn't normally exposed to the elements that would be the best route to take.
Tony53 Offline OP
Thanks Gene, yes I drilled it all apart and sent it off for re-chrome, then used the nut and bolt kit to assemble it again. Unfortunately I had a cheap chrome job done, which is apparent several years later. I think I'll just go with the wax as you suggested, as the car is stored under cover. I use the Meguires auto wax on the body, which doesn't leave a residue, so I'll try that.
Sydney, Australia
