#10876 12/09/04 03:45 AM
Hello
I miss for my 1930 the oil pipe line from the engine to the oil pressure gauge.maby someone can tell me the diameter for the copper line
Switzerland
#10877 12/09/04 10:07 AM
The parts book says its 1/4" and 47 3/16" long.
#10878 12/09/04 10:22 AM
1/4 inch. laugh laugh laugh
#10879 12/09/04 10:50 AM
Hello Chev Nut and Junkyard dog
Thanks alot for the fast information:-)))))))
Switzerland
#10880 12/23/04 10:34 PM
Switzerland----I believe the oil line is 1/8 copper---if you can not find local I CAN FIND AND SEND Little Six
#10881 12/23/04 11:35 PM
1930 used a 1/4" oil pressure line. 1931 used an 1/8" oil pressure line. The gages look the same except for the fitting in the back so it can be confusing. Then there is the 3/16" line from the oil distributor valve to the rocker shaft. Confused yet?
#10882 12/24/04 02:59 AM
Yep, as Chipper stated, in 1930 the oil line is 1/4", not 1/8". laugh laugh laugh
#10883 12/27/04 11:45 AM
Switzerland, You can use European 6mm copperline with brass pearl. It fits. Finn
Finn
