#108536 10/10/07 04:55 PM
woody Offline OP
What size are the threads on the shaft the pulley goes on? I dropped the alternator on the threaded end and need to dress the end to put the nut back on,it does not seem to be a standard thread. Thie is on my 63 impala
woody
Wilwood Engineering1955-1957
I dont know the thread size but if you have a set of jewelers files work from the good side to the end that will work. the knife and triangle files work best.
Eldeeb
_________________
Keep them running
trucks are cool
Its a 5/8"-20 thread....If it is damaged just at the end I usually file off the damaged threads as the nut goes past that area when tight.
woody Offline OP
Thanks guys,I tried my thread files and that didnt work so will grind the end off.
woody
