Could someone describe to me how the parcel shelf fits with the rest of the wood structure? I.E. does it go under or between the belt rails? Does it go under or between the two blocks that are under the belt rails and that appear to hold the upper end of the trunk wall braces? Hope someone can help me with this. It is an Entler piece and should fit. I just can't figure out where and how. In the only picture I have of that area of a car, it appears to be well below (6-8 inches)the bottom of the rear window and the top of the seat back.
Thanks, Pat
