Focus Offline OP
Does the primary (long Pad)go on the side facing the front of the truck or to the rear of truck and is the same for rear wheels also?(This is a 1959 Chevy 1/2 ton truck)
Wilwood Engineering1955-1957
To the rear. The short front show helps to push the long rear shoe against the drum. This is called the self-energizing feature.
