#107517 09/18/07 11:23 AM
Is there 2 different jacks for the 48 truck and 48 passenger car?chef
chef-chevy #107522 09/18/07 03:21 PM
My '52 half ton has an under the axle jack under the seat and for cars - at club shows I have seen two different jacks judged to be correct. My '48 car has one of them. They are bumper jacks...
chef-chevy #107540 09/18/07 08:22 PM
Its very possible. At the Eastern 6 Cyl. Tour last week we were comparing 1949-54 jacks and foun two different types. I am sure that Chevrolet had more than one supplier. In the 1955 -57 years there are even three for each year. The 1949-54 jacks had different lookingposts. One was V shaped and one hollow and almost square. The bases were also different looking but of the same size.
The 1949 info, says the 1948 jack base was seven inches square and the post mounted in the center of the base. In 1949 the base is 8" square and the post mount is off set. The minimum jack heoght for the 1948 was 7 5/8".....the 1949 6". All these jacks were the ratcheting type. The click-click type. All furnished would have these demensions. Some earlier years also offered an accessory friction type jack. The ones I have seen were painted green. The production jacks had a black ratcheting mechanism.
Perhaps some of the above will help to guide you.
Chev Nut #107549 09/18/07 09:40 PM
The jack I have has a 7 "square base and where the ratchet meets the bumper there are "v" shaped notches.I was told it is a 48 truck jack?chef
chef-chevy #107554 09/18/07 10:29 PM
The trucks did not use a bumper jack. They came with a screw type axle jack. Sounds as if its a car jack. :)
Chev Nut #107587 09/19/07 02:25 PM
In my post above I didn't mention that my '48 car jack is the friction type. And it doesn't raise the car high enough in the rear to get the spare back on. And the friction characteristic doesn't inspire any confidence in me. I use a later ratchet type bumper jack and on the rear I use it and a small screw type under the axle jack together so the car doesn't have to be lifted so high...
Chev Nut #107600 09/19/07 09:55 PM
I found some info on my jack..It is a 1941 universal jack.It kinda has a cactus arm look to it.There is coding stamped on the ratchet assembly,one side is 2 & A in a circle..on the other side is 4 0 or 8 & 0??I am to understand 41-48 are the same jacks??chef
chef-chevy #107602 09/19/07 10:09 PM
The Universal jack sold thru the parts department is not always the same as the factory supplied jack. It is just what it says, a Universal jack made for many years of cars....can you send a picture?
I sent you some pictures of a 1941 jack )and tools)
Chev Nut #107639 09/20/07 09:04 PM
Great pics Gene,my jack is close to the pics you sent.I also have a 1940 jack and I think it is just that and correct.The site I have found drawings of the jacks and tools are at 1940chevrolet.com,no 48 stuff though,chef
chef-chevy #107642 09/20/07 09:16 PM
The 1940 jack is different because the hook does not go under the bumper bar as a 1941-48 does. Rather the hook is placed under the bumper brackets and it has a V depression in it to keep it from sliding off. The 1941 has a rear slpash pan so the brackets are concealed, ditto for the rear and front in 1942-48.
Chev Nut #107647 09/21/07 07:35 AM
I have pictures of the 1948 jack that I will post this weekend. That is if I can get them posted. Hopefully that will help you.
This jack was in the car when I got the car. I was told this is the jack that came with the car when new. Since the previous owner knew the car since 1948 I have to believe the story.
Chev Nut has seen this jack and confirmed the correctness a couple of years ago.
Member 45+ years, been around since the beginning !
Chev Nut #107648 09/21/07 07:35 AM
Chev Nut #107649 09/21/07 07:35 AM
Chev Nut #107650 09/21/07 07:35 AM
VCCA Son #108034 09/29/07 04:16 PM
The difference I found with my jack compared to the pic sent to me buy Chevnut is...the pictured jack has its support housing for the ratchet mechanism at the bottom and mine has it at the top?????all else exactly the same...Very strange...the jack's shaft is 30"the support piece is 3"leaving the the lifting distance 27"high enough to change the tire,chef
chef-chevy #108196 10/03/07 05:33 PM
It would benefit a lot of us if you guys would post pictures here, so we all can see and learn. Thanks
Russell #38868
'48 4 door Fleetline
ruscar #108197 10/03/07 06:03 PM
I would need a brain to do that....but I do agree.
The tool man is planing on doing some jack articles for the G&D.
Chev Nut #108210 10/03/07 09:01 PM
My son has suppose to show me how to post pics many moons ago but you know how that goes,chef
chef-chevy #108218 10/03/07 09:48 PM
I believe that a new method for posting pictures (for dummys) is in the works.
chef-chevy #108227 10/04/07 03:17 AM
I suggest you use grandsons, they are much more savvy.
Agrin devil
Chev Nut #108308 10/05/07 10:33 PM
[Linked Image from pic50.picturetrail.com][Linked Image from pic50.picturetrail.com][Linked Image from pic50.picturetrail.com][Linked Image from pic50.picturetrail.com][Linked Image from pic50.picturetrail.com][Linked Image from pic50.picturetrail.com]
I bought this jack sum 5 or 6 years ago from someone through the G&D as a 1948. Gene said, "Some earlier years also offered an accessory friction type jack. The ones I have seen were painted green". As I looked at this closely, I can see that this was at one time green. So, exactly what year/years would this be correct and would it have been bought through the "parts department"? Their is writing on both sides of the body, but there is so much paint on it I can't make it out. Looks like JOSEPR MICH MADE IN USA PATENTED on one side can,t make out anything on the other.
ruscar #108309 10/05/07 11:07 PM
The friction jack was also called the "Universal Jack".Its is shown in the 1939 accessory book but looks slightly different from yours. I would guess that minor changes were made throuh the years. From what I can find it was sold from 1939 through 1948. I think I have some later pictures but can't remember where they are. Will continue to look. blush
I am 95% sure your jack would be correct for your 1948.
The tool man did an article about a 1941 friction jack. It was in the G&D in about 2000.
Chev Nut #108318 10/06/07 12:10 PM
I did more jack research-
The so-called friction jack is described in the 1939 Accessory book as "GM's universal Bumper Jack" ,Was mde by Auto Specialies Mfg. Co. in Windsor,Ontario. It described as being for all year cars. Was accessory #985377 and sold for $3.95. This sane jack is shown in the 1940 and 1942 parts books, same number and price. I don't have a 1942 or 1946 book and is not listed in the 1947 or 1948 books. Would assume that it was not sold after WWII. The 1948 book lists a new hydraulic bumper jack, #986141 for $15.00. The Engineering Feature books says "For those who prefer a jack the operates even more smoothly than the one furnished with the car, a hydraulic type bumper jack is now available. This light weight cast aluminum unit is operated with a 15" lever , and easily raises the car to a proper height for tire changing. Opening a valve lowers the jack smoothly."...and another "mechanical type" #986177 is mentioned but thats all I can find on that one. Also sold as a replacement part was a "replaceent jack" 609956, which would have been something to put in the trunk of a used car.
I guess I raised more questions than I answered. :confused:
Chev Nut #108327 10/06/07 03:04 PM
I too have been wondering about this type jack. It came with my '48 convertible which I bought in 1970. The car was assembled in the St Louis plant. It's 29 1/2 inches high in the base. The base has a lock ring to keep the base on. It looks like a twin to the one pictured above. But, when I got it, there was no hint of green paint. If anything it was natural in color. When I showed the car back in the 80's I painted it semi black. The lettering mentioned above make it certain that mine is nearly, if not a twin to the one above. The lettering on one side: first line ST Joseph MICH second line, MADE IN USA third line, PATENTED... On the other side it's harder to make out: first line, YV OLFWPP IWGHT (the YF looks like a logo because it's much bigger and the two letters seem to be connected)... second line, HAN--- HE-LAND third line, PA-SS DOWNLIGHT- Yes, I know it doesn't make sense but that's all I can make out of it. ST Joseph,Mich is a lake resort and it is/was an industrial center and twin city of Benton Harbor. Foundry and machinery are mentioned as products in my old atlas. Hope someone will be able to help unscramble the lettering on the other side.
Chev Nut #108331 10/06/07 04:02 PM
I have been searching for how to insert pics. If some one can point me in the right direction I can post a 48 jack.
Thanks in advance.
