Posts: 43 |
Require the Generator/Alternator & Power Steering Brackets (with bolts etc.) for a 1964 Chevelle with a 283. Also neeed a Quadrajet 4-Jet FRONT Inlet Carb or just the Carb Body! Also require an Air Cleaner - all must be 1964 Vintage! Thanks for the help, eh!
Posts: 2,142 Likes: 3
Posts: 2,142 Likes: 3 |
A Q-jet will not work very well on 283, are you sure that you are not looking for a Rochester 4GC?
John
John
Posts: 43 |
Yes, as far as I remember, the carb on the car is a Rochester Quadrajet "4-Jet" carburetor. It's a "Square Bore" NOT a "Spread Bore" carb. Should be a 220 Horsepower 283 V8. Thanks, eh!
