Posts: 521 |
Doesn anyone know where one can find the litte u-shaped clips used to attach upholstery on the older trucks? ron
ron
Posts: 934 |
OSCAR ALBRETSEN
Posts: 2,073 |
I you are asking about the clips for securing the fabric to the spring then do a search for Hampton Coach. They have them listed in the online catalog with the tool. I think they are called pig rings.
Chat Group Chapter Member Current rides; 1968 Camaro rs/SS 350 4spd 2000 Blazer LT 2005 Malibu Maxx 2007 Acura TDX Last total restoration; 1932 Sport Coupe
I think they are called pig rings. Actually, they are called "Hog" rings.  :) :grin:
Posts: 865 |
Actually Chevrolet did use U shaped clips to attach the upholstery to the seat back frames on some of their early trucks but as stated upholstery shops replaced them with "hog rings"
DD
Posts: 521 |
I can use hog rings but someone must still produce the little u shaped clips.
ron
If you are talking about the "U" shaped clips that are made out of spring metal, you can probably get those from your local upholstery shop also.  :) :grin:
Posts: 74 |
TSC (Tractor Supply Co), a farm and home store, carries three sizes of Hog Rings in our local store. I did not notice, but they may also carry a Hog Ring Pliers for closing the little buggers.
1934 Chevy 1 1/2 ton Farm Truck 1936 Chevy Master DeLuxe Series FA 5-window coupe 1961 Chevy Series 10 Fleetside 1963 Dodge M37
Posts: 11,162 |
As an Arkie guy like the Antique Radio Mechanic guy probably also knows as well as this transplanted Okie knows. The original use of "hog rings" is to clip them in a rooting hog's nose to keep them from rooting the ground up. The rest of the story.....
Been there, Done that!
Posts: 934 |
OSCAR ALBRETSEN
