#106417 08/27/07 06:18 PM
BOPNZ Offline OP
Hi all
I am contemplating replacing the rear chassis cross member on my 1926 chev. I have read in a local restoration guide that it is acceptable to replace rivets with high tensile bolts however i was under the impression that rivets provide a far better join. What do people recommend, obviously bolts would be far easier but i dont want to compromise strength.
Ken
Without the proper equipment, your option is to use bolts. Use grade 8 bolts and lock washers. Will be stronger than loose rivets.
Agrin devil
I replaced the rear cross member/gas tank cover on my 27 a couple of years ago.. Using grade 8 bolts I ground the head to
simulate rivets and they look good.. The car has been trailered and several long tours and have had no movement or loosening of bolts.. Works fine
roy
It takes a bucking tool, pneumatic hammer with proper sized rivet tool and heat source. The rivet shanks need to be expanded to fit tight into the holes or else will be loose or loosen. Each rivet is heated put into the hole, the parts held tightly together, rivet head held firmly in place and then the other end hammered into place. Not too tough if you know what you are doing and have a buddy to assist.
You can eliminate the "buddy" if you clamp the bucking tool to the frame with some big c-clamps. Make your own bucking tool from a heavy steel bar by making a depression the size and shape of the existing rivet head (a ball shaped carbide bit in a die grinder will work).
I'm in similar position & I'm looking at button head allen screws & then fill in the allen part before painting. They too come in grade 8.......Joe
1931 Sedan Delivery 31570
1968 Z/28 Camaro
1969 SS 396 Camaro
Try this guy, all he does is supply rivets for the old car hobby, his specialty is Model A's but he has a lot of sizes and all of the tools.
http://www.bigflatsrivet.com/
John
John
1954 Belair Sport Coupe
1977 Monza Mirage 305 4 Speed
1988 Celebrity Wagon
BOPNZ Offline OP
Thanks for the assistance on this one chaps. It seems there is a web site for every need these days. I will go with high tensile bolts for now as my blacksmith skills are somewhat limited.
Ken
McMaster-Carr also carries mild steel rivets also Fastenal stores located around the country also carry steel rivets.
