#10583 11/12/04 09:01 PM
1931Sal Offline OP
Is there a way to reinstall the copper mesh into a 1931 air cleaner? It does't look like it comes apart. When I bought it there was nothing in it. Also what do I use if it is possible? Thanks
Sal Orlando
Chat Group Region Member
#10584 11/12/04 10:47 PM
Sal, I have taken my air cleaner apart, and it does take some time to do it but you can do it. using a small screw driver, and hammer you can get the crimped edge open, once you get it open you just work it around the edge and it will open enough to get it apart. After you install the new screen put it back together, and tap the edge back down I had to do mine because it was dented. I clamped the part that fits into the carbuetor in the vice to hold it while I held the screw driver on an angle, and opened the edge. Good Luck.
Larry
#10585 11/12/04 10:47 PM
If there is no wire mesh inside of the air cleaner, maybe you have a 1929 or a 1930 air cleaner instead? Each year (1929, 1930, 1931) used a different air cleaner and 1931 was the only one with wire mesh. :eek: :eek: :eek:
#10586 11/12/04 11:51 PM
While you are on air cleaners.what is the proper decal for the air cleaner? The common one seems to be from oil breather.
woody
#10587 11/13/04 12:07 AM
The correct decal is an "AC" air cleaner decal, and it is orange, blue and white as I remember. No one makes the correct decal for the 1929-31 air cleaners, and the 1931 air cleaner decal made by I&I is not only incorrect, but it is total garbage. :eek: :eek: :eek:
#10588 11/13/04 01:22 AM
For that matter the decal available for 1932 Air cleaners is also incorrect.
#10589 11/13/04 08:41 AM
Chipper;
In your last post, you say that the available air cleaner decal for '32 is incorrect.
I got mine from the much mentioned supplier on these pages. Is that one correct? It's blue with white lettering.
Chat Group Chapter Member
Current rides;
1968 Camaro rs/SS 350 4spd
2000 Blazer LT
2005 Malibu Maxx
2007 Acura TDX
Last total restoration;
1932 Sport Coupe
#10590 11/13/04 11:31 AM
I believe that it is the same decal. I think that one company makes it and then all the dealers sell the same decal. :eek: :eek: :( :( :(
#10591 11/13/04 02:43 PM
1931Sal Offline OP
Thanks for all the input. The only thing that I still need is what to put in the inside and are there any suppliers around? Thanks again
Sal Orlando
#10592 11/13/04 06:49 PM
Nope........no suppliers that I am aware of. However, a lot of dudes use a copper Brillo pad, and it looks and works well.
I take it then that you have the correct 1931 air cleaner? laugh laugh laugh laugh
#10593 11/13/04 11:40 PM
xxx Offline
Sal, Does your air cleaner look like this one?
http://cgi.ebay.com/ebaymotors/ws/e...1&item=4504214350&category=39405
#10594 11/14/04 12:00 AM
Gator......that air cleaner is not even close to being correct. And, Sal has an updraft carburetor, not a downdraft. :eek: :eek:
#10595 11/14/04 12:30 AM
xxx Offline
What year is it for?
#10596 11/14/04 09:10 AM
31SAL;
JYD has good eyes, as every dog should!
I used a heavy gauge steel sponge and painted it a copper color like the one that I removed from my 32 air cleaner. I don't know if 31 had a copper color or natural metal silver color.
Current rides;
2000 Blazer LT
2005 Malibu Maxx
2007 Acura TDX
1932 Sport Coupe
#10597 11/14/04 09:44 AM
Speaking of air cleaners, one of the few things missing from the car I just bought is the air cleaner and from what I'v seen on ebay and on online catalogs they are not reproduced and originals are hard to find and very expensive.Any sugestions till I can find a goog original. Thanks
bob king
#10598 11/14/04 10:20 AM
Bob.
I'm not sure what you have, but most aftermarket automotive stores sell those small 2 barrel chrome air cleaners. That might help for now.
Current rides;
2000 Blazer LT
2005 Malibu Maxx
2007 Acura TDX
1932 Sport Coupe
#10599 11/14/04 01:30 PM
jtd and chipper: i have an original 29 aircleaner that came with the 4 conv landau. my 31 cabriolet was lacking an aircleaner when i got it. friend gave me what he thought was a 30 aircleaner. with the exception of the copper screen installed in the 31's , are the 29, 30 and 31 aircleaners identical? thanks, mike
#10600 11/14/04 01:55 PM
No! All three are different in configuration and each one is a one year application only. They are interchangeable with each other however, even though they are all different. laugh laugh laugh laugh
#10601 11/14/04 02:26 PM
Sal, About the material I found at my local industerial hardware store a bronze sponge.
it is called Kurly Kate special bronze sponge No.805 manufactured in U.S.A. by Purex Industeries, Lawerence Ma. 01840 the coat was about $ 2.50
it fits in the area perfect and is the correct color.
Larry
#10602 11/14/04 02:53 PM
About the correct decal for the air cleaners,if there is not a correct decal? Why does some one with the correct decals step up to the plate, and make the correct one or ones? With todays technology it would be not hard, and the cost would be not much at all. As I have said before if we are ever to have correct cars, and have them judged honestly with the correct items We have to make that happen. I know that we are not restoring Pebel Beach cars, and I think many of our restorations could be judged there and come home with a trophy we still have to reach for that with correctness even if it with a decal or a nut bolt or screw.
Larry
#10603 11/14/04 02:53 PM
thanks dawg. looks like i gotta find a 31 aircleaner. mike
#10604 11/14/04 04:07 PM
since the '29-30 air cleaners did not have any mesh, has anyone any thoughts about any filtration material for better protection (during times of general driving, not judging, of course)?..
any harm to adding the '31-type mesh or placing some sort of sock over the air cleaner?..
ok epi
#10605 11/14/04 05:34 PM
No one has made the correct decals because, to date, no one has found a correct 1929-30 air cleaner decal to copy.
On the 1929-30 air cleaners you can put mesh inside but that would defeat the purpose of the design of the air cleaners. The fins on the air cleaners are designed to create a centrifugal force inside of the air cleaner to get the air to swirl around within in the air cleaner, thus depositing any dirt at the base of the air cleaner. The slot at the bottom of the air cleaner is for the dirt to fall out. Primitive....but it kinda sort worked. If ya wanna put a white sweat sock with blue stripes over the air cleaner I suppose it would be okay....also primitive, but it will work! ha ha ! :eek: :eek: :eek: :confused: wink
#10606 11/14/04 05:59 PM
Which poses the question, how do we know it is not correct?
Agrin
#10607 11/14/04 06:16 PM
About 15 years ago one example of the air cleaner decal was being made, and even though it was not totally correct, it was better than nothing at the time. The correct decal is shown in several 1929-30 filmstrips, but no one has found a good original decal to use as a sample for a reproduction decal. laugh laugh laugh
