Posts: 74 |
What is the correct vaccum line routing for the starter vaccum controller? Does the starter controller vacuum line go over and tee in at the distributor vacuum controller or does it route up behind the block and attach to the carbuator / intake manifold? What are the correct fittings and can 1/8" steel line still be purchased. I have only been able to find 1/8" copper lines.
1934 Chevy 1 1/2 ton Farm Truck 1936 Chevy Master DeLuxe Series FA 5-window coupe 1961 Chevy Series 10 Fleetside 1963 Dodge M37
I sent you some pictures.
