Posts: 562 Likes: 1
Posts: 562 Likes: 1 |
All new car engines are rated by liters, how do you covert that to the old cubic inchs ? Is a 4.7 liter equiv. to 350 cu. in. ?
Dick
Posts: 4,951 |
Hey Dick,
I don't have an actual 'scale' or conversion table at my finger tips. But in pretty close round numbers it's 60 to 1 (one). For example the Chev 305 is called a 5.0. Also note the Chev 350 is called a 5.7. As you see, both these come out pretty close.
Re your example, I'd say a 4.7 is a fair amount less than 350 c.i. More like 285 c.i.
Bill.
On liter is about 60 cubic inches.
Posts: 562 Likes: 1
Thanks guys, this old dummy learns something new every day, now if I can just remember it !
Dick
Posts: 2,157 |
1 cubic inch (ci) = 16.39 cubic centimeters (cc) or .016 liter 1 liter = 1000 cc = 61.02 ci  epi
Posts: 11,162 |
Yep, 61.02 C.I. is equal to 1 liter or 1000 cc. and 16.39 CC (.016 Liters)is equal to 1.00 C.I. (slide rule accuracy)
1 liters = 61.0237441 cubic inches (big bang accuracy)
I passed my arithimatik but got too used to having a secretary for spelinkg!
Posts: 128 |
Good Golly Molly, I haven't heard of any one using a "slip-stick" in 40 years. I do use your numbers and try to remember that 100 cubes is close to 1.5 litres. Actually as you calculated 1.638 litres
Posts: 11,162 |
Ha!..... actually I got those numbers off the vast path of cyberspace, the WWW!
Yep, I still use my Post Versalog for a backup, it doesn't require batteries or solar power. It is now 52 years old, works as good as ever. slip, slide, and squint!
Posts: 861 |
Tell someone of the calculator generation we built the first atom bomb and put a man on the moon using slip sticks. I still have several but only use them when I'm showing them to someone.
Bill
Posts: 128 |
Mine is a K&E LogLogDecitrig. A little older than my 50 Fleetine but just as reliable.
Posts: 11,162 |
...and you probably already have one of these, from eBay! ![[Linked Image from i11.ebayimg.com]](http://i11.ebayimg.com/07/i/000/ab/83/99d6_2.JPG)
