Okay, lets settle this quickly. Post here the date from the head and casting number. Next, the date and casting number from the block. Also the number found on the engine pad. Now, remove the exhaust manifold, clean the location on the head that the manifold covers. On the flange of the exhaust port, copy that number and post it here.
Finally, post all the data on the data plate either on the end of the seat, or from the plate on the drivers side floor.
If it is a closed car (Fisher Body) remove the front seat bottom and copy the number burned into the front board on the backside.
With this information we can make some conclusions.
Read all numbers very carefully and note the spacing of the numbers.
