Bud,
As you may know the letter followed by two numbers on the block, head, manifolds, transmission, bell housing and pehaps many other cast iron parts of the engine refer to the date in the following way: Letter represents the month with A = Jan and B = February etc (I may be skipped for Sept) and the next number (middle one) is the day of the month and the last digit is for the year with 8 representing 1938 and 7 for 1937 and 9 for 1939 and 0 for 1940 etc.
I cannot confirm or deny that such a system was used for the frame. The difference would be that the frame (being rolled steel) would be stamped after it was made, while the casting number and casting date are placed in the sand mold just prior to casting the cast iron part.
I hope someone else can verify.
