Page 2 of 2 1 2
K10, I have never heard of drilling a hole in your t-stat. I wonder why they don't make them with a whole already in them. I think I would fill the block up with anti freeze and then install the T-stat...Oscar :confused: :confused:
OSCAR ALBRETSEN
They do. It probably depends upon the application. On the thermostats for our '68 and '69 for example, they come with the relief hole already drilled in the flange.
wink :) :grin:
Cool JYD, I never noticed, probably because I was always looking for the arrow that goes toward the block when I install it. Thanks for the lesson everyone...Oscar ok ok :cool2:
OSCAR ALBRETSEN
By drilling a bleed hole in the tstat you reduce the possibility of airlocks on refilling the system but it also allows an extra bypass increasing warm up time and can reduce running temp in cooler weather.
Some tstats are made with a small valve that allows air to pass but when the engine is running the coolant flow holds it shut. These are not always available as a retro fit unless original design.
Page 2 of 2 1 2
