#103228 06/27/07 07:13 PM
Bud38 Offline OP
Trying to remove the kingpins from a 38 straight axle. I removed the kingpin lock pins and pounded out one side pretty easily. The problem one is another matter. I started out using a brass punch/drift with a regular ball peen hammer. After several hard licks, I could tell nothing was budging. I then used some pentrating oil and stepped up to a heavier hammer. No luck. I soaked the pin several times over several days and went back at it tonight with a large shop hammer. Still no movement, but the brass punch is showing the battle scares. Is there a better solution to this problem, that I am apparently overlooking?
By the way, this supposedly unmolested straight axle had two different spindles, both use the same diameter and length kingpin, but different bushings. The problem kingping has the correct spindle. Any insite appreciated.
The knuckles should have been the same. Try using a gear puller to drive the pin out. Have you removed both the top and bottom plugs?
Brian
Bud38 Offline OP
Yes, the plugs were removed. The spindles/knuckles look the same, but the bushing outer diameter is smaller on one spindle and the plug was smaller for that one.
Use a torch to heat the end of I-axle. The spindle with the smaller bushing is a orignal and the larger one has been replaced with a later design spindle.
Bud38 Offline OP
Pump Jockey, What king pin kit do you ask for when using the small bushing spindle? I bought what was supposed to be a 38 kit and it will not fit the small bushing spindle. Am I correct, isn't this supposed to be a "floating" bushing?
The original knuckle fit 1937-39 str. axle cars. The 1940 Str axle car had a new knckle. It eventually replaced the 1937-39. When this happened a new bushing is mentioned, There is no clear explanatios in the book.Either pin should fit in the I beam the same. I would suspect one is rusted in. Not unusual....torch time. There is only one king pin set listed in the parts books from 1939 up through 1954. Thats about all I can come up with.
The bushings are full floating.
Here is a tip from long ago experience on king pin removal.
I noticed some one suggested a Jack under the axle another a hot wrench.
Let the jack down on a solid block of wood or metal, as the hydraulic jack absorbes a lot of the inertia. Place it as close to the pin to allow for it to move, so the axle will not absorb additional inertia.
It worked a long time ago!
