I'm Looking for a good 1928 (or other year ohv) chevy 4 cylinder engine in good shape. Something that either runs now, will run, or just needs some work....the closer to Pennsylvania the better!! Looking to start a project.
Thanks in advance!
Bob Rufi never died, he still lives in the dust and wind of the Muroc dry lakes!
How about a whole car? Aluminum over ash framed body, '27 block, counterweighted crank drilled for pressure, 3/4 cam, three port head. four speed all synchro transmission, 14" dia. front brakes,Ford wheels and axles. PA antique title. Photos available. Not cheap, but considering all the work and time invested----- eMail ebtm3@juno.com. located SE Penna.
When I works,I works. When I stops to think,I goes to sleep
Hello cowboy
I understood you are starting a speedster or other four banger project. I do have three complete engines, but there is no sense sending these to the other side of the world. You will most likely find a better engine much closer from North America. However, I have a same plans going on and I wonder if we could change information during the project. I'm a total novice what comes to 20's Chevies, so all knowledge is welcome. My biggest missing part is the correct frame, as you have probably noticed from the earlier posts.
Risto Nurmi
Oulu, Finland
p.s. If the 76 in your nick is your year of birth, it makes us the same age.
# 45414
I have some here in VA.
