Posts: 47 |
The tapered screw retaining the outside door handle in the right front door lock on my 48 4dr Fleetline is damaged. The sides of the screw head have been chewed off, thus no slot for a screw driver to grab. How can I remove this tapered screw? Do I drill a hole and try to jam something in the hole to turn the screw? Thanks, Larry
Depends, is there enough of the head sticking out to use a small vicegrip? Drilling may damage the handle, but it sounds like you may have to sacrifice it to get it off. The tapered screw is a harden screw and may prove to be a real challenge to drill. Good luck, you may need it.
Posts: 2,433 |
Larry,
I just went through the same act you are describing with my 48 Fleetline outside door handle. Passenger side came off great, driver side was a bear. I wound up drilling a small hole through the tapered screw, tried an easy out and broke it because that tapered screw was really rusted in there. Then I drilled the screw out completely (use a drill bit a whisker smaller than the screw so you can tap the hole later). I did mess up the hole in the door handle shaft (didn't care because I was replacing the handle anyway). If you are reusing the handle and you mess it up, I think you can fill the hole with weld and redrill it if need be. Once you drill out the screw, you can get a small punch in the hole on an angle and give it a couple of sharp raps with a hammer to loosen the handle itself. The tapered screws are available from the Filling Station. Good luck.
ken48 VCCA 42589
Posts: 206 |
I had a problem with the trim retainer screws on a BelAir. Rusted solid with no head left to grip. An old machinist watched me struggle for awhile, then came over and told me to go to a good tool supply store and ask for a couple of reverse twist drills. They're made to drill counter-clockwise. I got them a little smaller than the rusted screws, put my drill on reverse, and went to work. Most of them backed out on the drill before I got all the way through. A few I had to use a small machinist chisel, light tapping in the counter-clockwise direction, and they all came out clean. Worth a try!
Gene
52Conv
