#101570 05/23/07 10:08 PM
PAPA-K Offline OP
I have vertical lift at the front of my hood, how do i adjust latch to be latched tightly? The shop manual is not working. thanks
Wilwood Engineering1955-1957
If by verticle lift you mean that the hood can be moved up and down when its closed-
The adjustment is made by the pointed center guide that it on the upper latch.You will see that the guide is threaded and locked with a lock nut.Loosen the lock nut and turn the guide (its slotted on the point) clockwise to shorten it.Go about two turns at a time.
PAPA-K Offline OP
EXACTLY GOT IT THANKS
PAPA-K Offline OP
I saw as soon as i looked at it the 57 latch is not the kind you are refering to, the center is all one piece with no adjustment there
Sorry, I was thinking of my '50.
The 1955 and up have adjustable screws with rubber bumpers - one at each side.They are on the hood and contact the outter ends of the tie bar.Are yours missing?If I remember correctly there is a little flat spot stamped into the ends of the tie bar where they make contact.I will need to get a good look at mine tomorrow.
PAPA-K Offline OP
ADJUSTING SCREWS ARE THERE MISSING ONE RUBBER BOTTOM HAVE ONE SOMEWHERE
on 55,
theres 2 bolts in front, 1 small bolt in back, loosen back, then take out 2 bolts, in front holding top latch on, put thin washer between bolt, each bolt, tighten bolts these washers will push out top latch out some , and hood will be tight.
