#101161 05/16/07 06:59 PM
How is the sheetmetal joined on the 23 touring on the back where you have the two large belts running vertical? Rivits?
1921 touring #101175 05/16/07 09:14 PM
Good Question, I have not torn my '23 down yet.
Hey ChevyB, can you take a picture of the '25 body?
Chris
1921 touring #101240 05/18/07 10:09 AM
If it is like all the other wood framed Chevys that I have worked on the individual panels are nailed to the wood near the edge of the metal. Then a metal molding with attached nails is nailed in place over the seam. Some use a fabric hidem welting around the tops and a few other places.
1921 touring #101283 05/19/07 02:36 AM
At the back of the "tub", the vertical belts are crimped together. There are no rivits. If these three pieces have separated, you have a bit of a job ahead of you. Perhaps you could sweat solder the pieces together, then place small rivits at the very top (which will be hidden under the upholstery) and at the very bottom (which will be underneath the car and not obvious) as "stiffeners".
I will try to get a couple of photos of mine and will post them up for reference.
1924 Superior "F" Touring Car
