RogerD Offline OP
Can anyoone tell me where to obtain the parts that go onto the bolt that secures the top to the canister to the base of my oil filter? I pulled it off today to change the filter and found it is supposed to have a spring, washer, and I think a rubber ring on the bolt. It has nothing on it. I have checked every site I can think of and cannot find a breakdown of the parts, where I can get the parts or a photo of the bolt and its parts.
Thanks, Roger
19514me
Roger, I had the same problem and had to buy a complete filter from ebay to get these parts. I think back and I should have searched for a spring that would have worked. I didn't have a spring or a washer for a long time and didn't have a problem with it. Good luck in finding these parts...Oscar wink chevy
OSCAR ALBRETSEN
You can probably get a universal spring and a washer that will work at your local hardware store.
wink :) :grin:
JYD, thats what I should have done...Oscar :cry:
OSCAR ALBRETSEN
RogerD Offline OP
Thanks Guys. Appreciate the response. If anyone has the size and or picture of the spring I could sure use it. I have checked the hardware stores here and can find all kind of washers and springs, but they all fit loose or too tight.
Thanks again, Roger
19514me
Roger,buy a tight fitting spring and cut it down to make it more loose. Sometimes in this hobby you have to do with what you have and make it work...Oscar :) :( cool
OSCAR ALBRETSEN
Try this picture Roger;
http://rides.webshots.com/photo/2990809770098611668nLLTVg
Denny Graham
Sandwich, IL
RogerD Offline OP
Denney, thanks, that is what i needed. I think I can find the parts now that I know what they are supposed to look like.
Roger
19514me
RogerD Offline OP
Thanks to all responses. While at the hardware store clerk asked if he could help. After telling him what I was looking for he said he thought he had a one of those things in his shed just like the one I described. Sure enough it was complete. I paid him $10.00 and another problem solved.
Thanks again Roger
19514me
