#100542 05/05/07 12:36 PM
tcgood Offline OP
On my 26 what would be a normal idel pressure, and full run pressure?
Thanks Terry
tcgood #100543 05/05/07 02:12 PM
If you are able to achieve approximately 2 lbs at idle and perhaps as much as 7 lbs at cruise, you are doing well. That assumes a fully warmed engine.
As I have stated numerous times before, it is volume, not pressure, that we want to achieve. Nothing on the 1926 engine is pressure fed. The object is to have sufficient flow to keep the troughs filled so the rods can splash the oil around in the crankcase.
Agrin devil
The oil pressure on my '28 truck will go to 15lbs. at cruising speed(50 mph)and idle at 10 lbs. with the engine hot,using Shell 20W50 oil.The pressure readings are(as Ray says)only an indication that there is sufficient oil volume flowing around the system,so I treat my gauge reading more like a mechanical warning light,then at least I know my oil pump is working O.K.
chevy
CJP'S 29
tcgood #101230 05/17/07 10:33 PM
hi, i have a 28 chevy runs at 10 psi full open, i am looking for info and or value on this truck, any one can help is great, jlakey@razzolink.com...
Lakey2223 #101242 05/18/07 10:19 AM
The value depends heavily on the condition and body style. You can check several online value guides. Kelly Blue Book, NADA have them. Run an online search for them. Sorry don't have the addresses on this computer.
CJP'S 29 #101243 05/18/07 10:28 AM
CJP's29,
I would suggest you change oil to a 10W-30 (or even 5W-20 in cooler/Northern areas). The piston pins and cylinder walls are lubricated by splash caused by the projections on the bottom of the rods passing through the troughs. If the oil is to viscous then the droplets are not fine enough to properly lubricate. If you think of the lubrication similar to that in a 2-cycle engine (oil mist) then you will have it about right. All you need is any positive pressure at idle (indicates that oil is flowing). Also remember that you are trying to get pressure from an open ended set of pipes.
Chipper #101300 05/19/07 05:44 PM
Hi Chipper,
"Down Under" in Australia,I think a 10W or 5W grade would be too thin.We don't get the really cold weather here like you blokes do,and that's why I run the 20W50 grade.
I've shone a torch down the oil filler pipe,and there is a veritable rain storm of oil flying around,and the oil really gets moving when you rev the engine up.
chevy
CJP'S 29
