#100486 05/03/07 07:37 PM
Landman Offline OP
Are the spare tire covers the same for rear mounted spare and sidemounts on a 34 Master? Or are the sidemount covers cut to follow the fender profile?
Thanks, Landman
The tire covers are the same.The lower part will just be hidden in the well.
There are two types of tire covers for 1934 Masters.One is the ring type and the wheel is exposed.The other is the drum type that covers the wheel and tire.Either can be used for side mounts but the ring type was most common by far.Was just the reverse for the rear mounted spare.
